LazyServer
- Dec 10, 2004
- 41
Hi ALL,Recently, my UDM (e36, 325i, auto) seems to slam into gear while shifting up and sometimes down (most probably to or from 2nd gear).The problem is, this event will only happen once, through out the driving and will only repeat (intermittence) after I shut down the engine and restart. My mechanic could not diagnose this, as this problem is intermittence. Check speed sensor, atf level (no leaks etc), mounting etc, everything is OK.I have overhauled my gearbox 2-years back and will try everything else before taking it apart again.Any ideas or suggestions from the forummers are most welcome.Thanks in advance. LazyServer
