Gearbox problems
rx7soo
Hi, Everyone Yesterday I have change my clutch set (Clutch plate/cover/bearing(LUK) & Flywheel bearing) is due to my noisy gearbox so decided to change everything. Which before this I have look for my mechanic he told is the clutch bearing either flywheel bearing then we took out the gearbox now he said is the bearing inside giving sound. The sound is something like bearing touching in a hard surface but not (Klok klok) is rough sound of metal and he showed me the stick (refer the image which highlighted) of the gearbox is moving/loose when rotate it the sound is rough he told methe gearbox is die.DO YOU AGREE WITH THE ANSWER?Before this I have change my gear oil 2mths ago (Castrol Gear protection 80/90EP) I told him could it be the gear oil he said NO. Ok everything installed new clutch set + flywheel bearing & exsiting gearbox = noise still there. And have to change gearboxAt night went try it, something which is not right when I pressed the gear pedal is smooth & light (same with Fabian when pressed no sound depressed sound is there normal) to engaged to 1st gear but is harder now then before I have to push in like twice/2steps is like something blocking even I pump my clutch pedal. I have to push in quite hard, is not only 1st gear/2/3/4 but 5th gear is smooth & quiet even running. He told me is the bearing in the gearbox not schcnorize. Few week ago, Car jerking factor is from the gearbox. The mechanic said the jerking is because of the gearbox is faulty so all the power is pulling by gearbox so it jerk. I have told him that I broken a nut at the throttle body the screw/nut is a size (8) which i think is adjustment throttle timming. He told me that is not the issues of it. CAN ANYONE HERE CAN GIVE ME AN ADVICE/ANSWER? YOUR ANSWER WILL BE APPRECIATED. THANK YOU:wink:
Hard to kill a manual, but if you have changed everything else in the clutch I would say it is something inside.. good thing about manual's is that there is not alot inside like auto's so a complete rebuild is possible fairly easy.
not very sure of the problem, but im having problems in my gearbox as well, loud cracking sound when i engage to every gear. I think it's due to the pressure plate, gonna open up the gearbox tommorow and check, its an E30 btw.
