E36 Front Interior Lights Into a E30...
Hahahaha.... Mine would be my next DIY....
Converting Engine... hehehehe...
All the best Bro...
Just to let it be clear...
If you have the check light on top...
You just use the main direct ground & power from the check light...
then have one wire connected to the original door switch which is at the original door light...
All the best bro...
You're Welcome bro... All The best Man..
Just to be clear... If you do have a Check Light On Top...
Then use just use the Direct Current (Grounding + Positive) from the check light...
and just only one wire straight to the original lamp where the door sensor is...
My next DIY is overhauling an engine & shove it inside my E30... hehehehe...
All the best man...
what the hell man?u r damm good..wish i could do the same...
u got some talent bro...
What unit...? The interior lights ah...?
I'm looking for the E36 Under Dash lens...
Plus i don't mind maybe buying another E36 Interior light & taking it apart...
I want to custom the Circle Light Frame to lighten up my interior when I'm driving @ night...
It would be done one short...
Cause now...
I'm looking for...
- 2x E30 Interior Lights
- 1 x X5 Slow deeming light system
- 1 x E60's Side mirror... ( Funny thing is... I want to do the light beaming that they have on the E60 onto my E30...)
- 1 Set of E36 Under-dash board beam light...
- 1 x E36 interior light's set (Again...)
hehehehe....
After doing up my engine... & Body Wok...
That would be my next DIY... Making my interior modern feel with Classic Look...
Don't worry... I would post up.. how to overhaul a M20b25 engine...
and also how to re-do and knock back Rust Body & Dented Surface....
All DIY BABY.....
I LOVE DIY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nice oh... Did you put adjust the light to shine down wards ah...? cause if you don't it'll shine straight to your face...
yes...
since the original lights are diffficult to reach, after moded e36 light now its very easy and helpfull at the night to see things.
I'll recommend to fellow e30's...
