my rear window blind is not operational since i got the car.there is power to the motor when I select but the blind does not move.Suspect some gears stripped or something.Anyone know who can repair this ?
This is a common problem in e34 as this is rarely used. The motor usually fails and has to be replaced. It is very difficult to find a second hand one. Some people hzs told me that the motor is same as the one used in Merc.
Anyway, I gave up after looking for it for 2 years and bought a brand new one for about 700 MYR
Any mechanic should be able to open the rear shelf and check it. If you are lucky, it could just be the relay on it which is faulty
my experience is slightly strange...the window blind stopped working when my aux fan stopped working. after doing some re-wiring and with some extra fuses to fix the aux fan, the window blind started working again! and it's been 3-4 months now, so hopefully it'll continue working...:106:
I don't know if the E34 rear blind has the same operating system as those in E32's. From what I know of the E32's it's usually the plastic gears that has gone bad.
it d plastic gear wear n tear, unless u can replace the plastic gear, no permanent solution. i ve chk,no one sell the gear alone. if u can get 1, let me know.
