kung,
maybe you can be more specific with your restoration ?
For example
1) restore to stock/factory standard (with everything original). Then I can be the guy for you.
2) restore to M-Spec (also can be help)
3) restore to your standard (you need to define what you expect from the car)
It can be done step by step (for original restoration).
1st, we need to access what stage is your car. Then we start from mechanical 1st to ensure the car is in running condition which includes engine, brakes, suspension, bushing,gearbox,drivetrain and tires. Then we go to your body works which includes paint, body works, mouldings, rust, exterior lights (headlamp, rear lamp,signal lamp,fog lamp) and undercarriage. Then we move to your interior which includes seats, dash, rubber seals and carpets.
Good luck
