e30 again!
Originally posted by pussy@Aug 3 2005, 09:50 AM
2cents, mine changed due 2 reasons.. steering coupling all gone :( and the other, my rack was leaking like mad.. to repair/change will cost me RM1450.. so by doing the conversion.. i get better upgrade and cost me Rm1300 :p
now fast u-turn and better turning radius. :D
regards.
steering sudah upgrade ..
itu 4 piston bila pulak ?
Shaifulo
I think Pussy mechanic or Zoggee's will be able to help if they can get the right parts. Its not really a direct swap. Depends on you engine as the coupling will be in contact with the headers upon turning. Therefore you will need to fabricate a coupling. As for the formula for the fabrication I will email you. So please give me your email. With that it will be a direct swap.
2cents
What are the improvement or advantages?
1. E36 racks - easy to find anywhere.
2. Turning radious as TJ wrote is much better.
3. No free play. I hate it when i turn my steering & the car still goes straight? This is the remedy. Very good if you wanna track it.
4. Steering response will be more direct - Which is same as No 3.
& last but not least ITS BECAUSE ALVIN done it, Pussy followed him & did it, Kaki Puchong also did & still is smiling bout it.
Muahaha ha h ah h ah haha h ha ha!!!!!!!!!
Now i'm charging for all the R&D work! I'm open to be bribe! heheheheheh :p
alvin,
sent u a pm.
i never knew it can be done in Malayaland :D ....only seen them over the net
by the way, did u fit a heat shield to the coupling?
i think fitting into mine shud be much easier coz its an M40 only.....A LOT & LOT of SPACE!
i asked around and it seems E36 rack is cheaper than E30 aluminum ones!!! good reason to do it...
hah... B) why everybody with e30 got steering rack problem ah..??? :)
it is the 2nd best upgrade if you get ur hand on a E30..not the exhaust,not he chip...not even the engine.
wanna know whats the best ....
ask me how I know... B)
oi oi oi o oi......
stop it or i'll sue you big time..... :getyourfactsright:
or maybe i lelong the doggie....... :p
Originally posted by Alvin@Aug 4 2005, 04:55 PM
Shaifulo
2cents
i get a small percentage for marketing the concept ya boss...? :D
Originally posted by shaifulo@Aug 4 2005, 10:26 PM
alvin,
sent u a pm.
shaf,
diff cars, with diff engine will have diff set of modding problems :eek:
if you are lucky, then maybe you wont have any at all :lol:
best to check with meow ow if he had any problems :D
Originally posted by iCe@Aug 4 2005, 10:49 PM
lari topic sikiit~
what is m20,m40,m50 summore?
sorry~~
M20, M40 and M50 are the engine range..
M20 for the 6 cylinder 12v.
M40 for the 4 cylinder 8v.
M50 for the 6 cylinder 24v.
shaifulo
Yes it can be done in Malaysia cause i have talk with Ian in th UK. However, the measurements in the web is slightly different.
Taikor Zoggee
Pls advise the list of best upgrades in descending order+ cost involved for each one..very interested to know TQVM :D :D :D :D :D :D
btw can the parts be acquired cheaply from chop shops here in Klang valley? mucho gracias :)
Originally posted by 535i@Aug 3 2005, 03:30 PM
But E30 M40 is famous for the 'free play' not so much with the M20 though ..
Hv changed the rubber thing countless time .. sama aje ..
mebbe it's time for you to change the metal U joint coupling (big money here).....or have the rack rebuilt or better still ingest the racun.
bmwky was in his diapers when 535 had the m40
even i had to learn from the mahaguru then........!
no lar, trying my marketing skills......
if got more ppl upgrade i get commision from the original racunner lar.....
come Larr!......mod Larr!.........no balls ahh!!!!!!
