DSC light on! HELP 730i E65
hellgrace5
Hi. I have a 730i E65 and the dsc light is on. When i scan dsc with X431 Diagun it shows :5f02 internal fault, DME/DDEi search on the net and 5f02 was wheel speed sensor general ?Can anyone help me with this fault ?
try to get the wheels off n clean all four wheels speed sensor because they might get dusty from brake dust. if still on, then no choice need to get diagnosis tool to pin point which is the onw faulty.
@update
cleaned all the 4 wheel speed sensors. DSC light is still on. All sensors are working when i use data stream on my launch x431 diagun.
Someone any idea about 5f02 code ?
A competent BMW specialist would be your best bet to fix your problem. Only a small number of forumers are technically inclined.
yes, e28 driver is right...
can be the wheel sensor, connection sensor wires, the DSC unit it self, the ecu for it blah, blah..
