Boot/Trunk unable to lock
yapmy
Member
Hi guys. I just randomly discovered a weird problem whereby my car's trunk/boot is able to open using the release button (above the number plate) without the key fob present (key fob is inside the house) while all 4 doors are locked. Any idea what could be the cause of this problem? I'll definitely need to fix this security flaw if I ever want to put stuff in my trunk.
Update: I found out that the issue was caused by Coding via Carista. Problem solved after reversing the trunk related setting in Carista.
Case closed.
