astroboy;677797 said:
In my pre-LCI, I just switch on my yellow spooky corona rings if I want attention, plus fog light is I'm a bit fast, plus head light if I'm more fast.. high beam if insanely fast.. :4:
The LED strip is so un-BMW.. I can understand if it's meant for Audi convert. No thank you! :48:
Nice meh?!
From this photo, u can see the original LCI corona ring carries more character then the cold blue Audi wannabe strips..
Unfortunately, this is the LCI with brighter AEs than pre-LCIs.
I think for my pre-LCI, my options are:
1. Upgrade AE DRL
a. Upgrade my current WeissLicht LED AEs to WeissLicht LED Version 2 - USD149 + shipping + tax?
WeissLicht AE LED upgrade kit
b. Do what this guy did, using a control module:
AE DRL mod - EUR149 + shipping + tax?
Cost: RM1.1K + shipping + tax + time/effort to reprogram
- unless Ingress is willing and able to reprogram the computer to just turn on the AEs when I switch to DRL mode (currently the computer turns on both the AE and Xenons when switch to DRL mode), in which case, cost goes down to RM475 + shipping + tax + Ingress labour charges
Caveat: Will the WeissLicht LED Version 2 be as bright as the F10 AEs?
Pro: If sufficiently bright, this is the ideal config
Con: Higher cost if require the control module, or if taxed heavily by Kastam, but can reduce a bit if I find a buyer for my WeissLicht Version 1's.
2. Buy the BMW/Philips LED bar DRL
Cost: RM850ish + Ingress labour charges
Caveat: Must find out how the LED bar works in conjuction with the AEs and other lights in the various settings.
Pro: Quick and easy
Con: Not the ideal look
I think I will ask first if the Ingress guys can reprogram my car so that only the AE's turn on in DRL mode, then I will go and switch out the LEDs for the Version 2's. Otherwise, I may go for the LED light bar. It's just a stopgap measure for a couple of years (hopefully no longer than that), before the SKD/CKD F30 shows up (eyeing that N20-engined 328i).
