sewell
- Dec 7, 2009
- 632
- 18
ken007;519804 said:When you jump start it, the alternator is constantly charging up the battery hence when you reaches the battery shop it already fully charge. If the alternator is not charging, a battery icon will pop up in the dash meter. You can measure with a volt meter when the car is sucessfully started should show 13-13.7v. Turn on head light, radio and wiper you will notice voltage drop to below 12v and slowly the alternator charging will increase the voltage to above 13v.This show the alternator is charging and is good.
The amper is needed to crank start the car.Check the rating on battery something like 60 or 70Ah.At least 70% of battery Ah is needed to crank start the car.when the car cannot be start, connect the battery tester will tell you whether the battery is in good condition.For all BMW car when ah drop below certain low level.You can't start the car at all not even a cranking sound. This is to prevent the electronic system being damage by low starting voltage and ah.
For BMW car because the whole electrical system is constantly drawing high load from the battery hence only replace those premium brand battery.Other asia brand battery will not last and at the most give you 1 year life span.
Thank you for giving so much information. after jump start drive to the battery shop to check my battery have 82Ah and i think this is very good (i did not notice the voltage). for your information my battery is BOSCH DIN88 S5 series.
