Ac Synitzer
- Nov 2, 2011
- 49
How much to replace a new ASC Controller?Is it Important to replace it Fault?Pls advise?
Ac Synitzer;706355 said:How much to replace a new ASC Controller?
Pls advise?
xcrave;706437 said:I do... it saved me one day during a rainy day... my rear tire was slipping from sharp conering... ABS kicks in and it brakes the exact tire which is slipping... could be a serious accident otherwise...
When BMW design the car it has safety in mind for its heavy sedan... why ignore it...
Change it ASAP as it may save your life... money cant buy that
Slips;706613 said:The link provided by xcrave did mention that ASC would apply brake the a wheel that's about to spin...
I think I've experienced that feeling once...
Taking a corner fast and felt 2 rapid braking sensation while I just pressed on the gas pedal...
Hi Bros,
This is exactly the thing I was thinking about. Can the brake servo do the braking for you or is it only capable to release your braking pressure.
I always thought that when slipping happens - wheel spin too fast, power will be cut off.
and when locking happens - implausible deceleration, brake pressure is released
And I agree both traction control, stability control and ABS are handled by the same control unit.
I remember reading the user manual saying that when cruise control is turned on, the car speed may exceed the set limit if engine braking is not enough to slow the car down. Sounds like the car can't apply the brake on its own.
xcrave;706557 said:ASC controls it all
tweiboon u need to read more... its not a Jap car...
http://www.318ti.org/notebook/asc/index.html
This technology is already there starting the 90's thats why when ur ASC screwed ur car is nothing different than other cars with ABS...
Basically ABS is only part of ASC function cause u have the Break Servo... ask anyone here they should back me up on this...
Good luck on ur ACS-T --Less Car
waichon;713871 said:So means do we need to on the asc all the time?or during raining day?i sometimes try to on asc.felt abit different when driving.
haywire;713873 said:Bro you dont need to turn it on, its default ON all the time. When you press the ASC button and theres light on your dashboard, the ASC is OFF!
firdaus72;714449 said:Replaced mine. Around 4k+
waichon;714466 said:Oh.i tot is turn on when press it..really noob la..haha.so if drifting then don't need to turn on the asc?where to learn drifting?my fren saw me bought BMW then keep telling me that can drift the car coz is rear wheel drive.so I wondering how to drift?wherento learnt it,scared the car terbalik..
