Alarm Acting Funny? Any Solution
yoke
Mine is a 318 lifestyle Y'04. Whenever I lock the car using the remote key, few minutes (depends sometime more than 10 min), the alarm will start blaring. I would than have to lock it manually using the key. No problem to unlock it using the remote apparantly. The problem happen to both set of keys. Any forummers face the same problem and found a solution for it. Any idea guys.Thanks
mine also like this....
my pomen say batery going to kaput but i just let it be....
some fren say can be set....
dunno which really are....
helppppppppppp
This one ive heard from A lot of places... Its because of the "Hood Sensor" apparantley because of our climate the hood sometimes deform a little (Metal expand under heat) So the contact of the Hood sensor will sometimes be effected...
I suggest going to the selected woksop or "stealership" to test out replacement and if it works... yes thats the culprit...
Other than that Its true that a low batt amp also contributes...
[DIY] ---> Grease and clean the Hood Sensor... this is a short fix...
P/N 61 31 4 158 205 http://www.realoem.com/bmw/
i've already disconnected the hood sensor yesterday...
now the problem gone, i'll try to wait till this weekend....
if there's nothing funny came out then it sure be the hood sensor to be the culprit...
Are you saying, it's the front hood? Where is this sensor located, can you tell.. Thanks bro
xcrave;623796 said:
Read my post bro yoke :) above here...
yup...stated there....big thx bro....done mine....today oso nothing funny with my alarm....
would wait till this weekend....
here is the thing...
for me its better to just disconnect for a try....
coz this funny thing not happen all the time....
bcoz mine only acting funny at home....
*please bear in mind that this is my option...
if u wish to do the same, u r doing it on your own risk
Careful when disconnecting... and changing new one... disconnect battery (sorry forget to tell u guys this)
If got sot... then later have airbag warning...
