BMW Alarm System VS Add-ons
simonso
Need some opinionsI added a new alarm system kit with GSM and apparently after adding the alarm weird problems start occurring:-1. engine dies after 2 second of start up, then removed the anti-hijacking mode (this mode kills the car if stolen) after a day of removal, the car seems fine.2. air-cond not cold on start-up, but cold after a few KM of drive. (removed the whole alarm kit today)Test for a few more days first or else must see naidu already :eek:Currently using the key, but it isn't really affective. Sometimes it work, sometime it doesn't why ah?
E46 is a very sensitive car with all the sensors and what-nots. If you're fixing a external alarm system, you have to be very sure the car installing it knows what he's doing. So far, I have not heard of any case of BMWs being stolen. Thieves cannot hot-wire the car. Which is bad in a way, as they will then CARJACK you, which is a worst experience.
May i know what brand of security system are u using?
Mine are CAPTOR..so far didnt have any issue with engine or electronic system.
I just got it check with the wiring guys when the air-cond failed. Apparently it wasn' t the alarm but the bmw wiring man mention best not to have a GSM kit installed. Anyway i'll get him to re-fix my original alarm system. Currently the key is not functioning very well. That's the whole reason why i got the external kit.
Will get back to this post once i get that done.
Will get back with u on the brand.. :top:
A cheap solution is to put a cheap old mobile phone in silent mode in the car. then, you can use the telco's location base search for the car. Of course, remember to charge the phone's battery.
MSport - yeah that's definitely an idea. I bet you i'll forget to charge :p
