Aircond Problem
crAzyBiMMer
Hi Sifus, Need some advise.Driving E36, last week i went and added the Gas for my aircond... now after 1 week its totally blowing only wind.. not cold at all... any idea what could b d problem...
Two reasons:
1. Add too much aircond gas.
2. Cooling coil 'kong' oledi.
Visit Naidu if u stay in KL.
aircond matter is darm subjective one ... it could be many reason from a small alu pipe leak to a major cooling coil leak ...
best is get it inspected ASAP ..as due to the rainy season now .....
not that cheap these days lorrr .. last week had a tiny hair line crack at the condensor inlet and hell had to change the entire condensor which cost me RM420 .... shisshhh can't even weld it according to the sifu there
Basic aircond troubleshooting technique:
1. When switch on, compressor got kick in?
2. Ur car got aircond fan? If got, did it kick in after aircond switch on?
3. Check the filter dryer and see if there's a window to check circulating cooling agent. If there is, see if there cooling agent inside, or is there a lot of bubbles? A little bubbles are ok. To much bubbles means need to top up cooling agent. Full of liquid with no bubbles means overfill of cooling agent like what BMW7833 said. Not good to the system.
4. If cooling agent vanish not long after top up, must detect the leak, its either the hoses, aircond radiator, internal cooling coil or the valve.
If leaks, then replace the parts lor, if compressor kong, replace compressor lor, if thermostat fail, then replace thermostat lor, if valve blocked, then replace valve lor, if filter dryer blocked, then replace filter dryer lor.
Dunno what I'm talking about? then go to the workshop and prey hard lor.. :D
Sifus... Great advise!
Thanks a bunch to all da sifus in da house :)
Well i guess the best thing is to bring ma car to the Mech
I wanted to know all this coz afraid of kena Con big time as i'm not very sure of this areas.. ( aircond )..
hmm... everything was ok .. last week i felt like my aircond was not too cold and went topped up.. now the whole thing Kong oledi!
Well... thanks again to all... dunno how much i'm gona kena cekik this time $$$ :eek:
Take care all!
Oh yes.. bro BMW7833 can you lemme know whr is Naidu's workshop/place...
i'm stayin in Seri Kembangan.. no prob to travel within KL...
appreciate ur help...
Thanks!
Thanks!
U click on search then u know..He is our aircond specialist, almost lar..
I agreed with all our Bros suggestions & recomendations.
OR U can have your car check by Hup Huat Auto a/c service centre at Batu 5 Jalan Ipoh, KL.
Good luck
Thanks!
head into FED highway heading to subang ...just after the KL pintu gerbang , take the left exit (The EPF building is on ya left ) as soon as you turn left , take another left ( this time the EPF building will be on your left and Shell station on ya right )
drive up another 10M take right and you'll see naidu on ya right ....
all the best dude
all the best dude
Bro thanks for d guide... i guess shouldn't be a prob... i think i know how to get there now wit ur help....
Thanks to all again!
Cheers! :top:
All da sifus ,
Thanks for ur help again... got it done at Naidu's place.
Very well done.. clean job! :top:
Now, as i'm in d progress of adding some spice to my beloved ride... need more advise...
Can someone tell me how low will d eibach springs will bring down my ride ?
This will b for 4 pot... 318... :)
Changed my rims ( 17" ) last week in klang and now thinking to lower down d ride.
If i lower the ride will it touch the body ?? :stupid: hmmm.. not sure about this...
I'm using Tyre - 215/45/17
Thanks for ur time and advise!
:rock:
