air-con compressor clutch not engaging
hoesny
Hi....My ride is E46 318i (2001). Having problem engaging the air-con clutch; i.e it refuses to engage esp after parking the car in the hot sun after sometime. Have no problem with the air-con when car is started in the morning. Went to an air-con specialist - he recommended that I replace the whole compressor, but the compressor is still in good condition as it can still cool the car very well. Is there anywhere I can get the compressor clutch fixed (w/o replacing the compressor)?
If you are around PJ, I sugguest that you see Naidu. Most of the forummer recommend him for air con problem. I think his shop is near the old EPF building just off Jalan Gasing. Do a search on "Naidu" or aircon.
thanks
Hi jarance. Thanks for the info . Will try to look him up next time I'm in kl.:D
air-con compressor clutch not engaging.....
Hi,
Went to several workshop re:above, but none is able to have the clutch repaired at the workshop. A shop in JB said that it could only be done at a factory (meaning the whole compressor has to be taken to the factoy !)
A way out is to replace the compressor with a re-con of the same make and model so as to ensure compatibility.
Here's what a shop in Tmn Skudai did to solve the problem:
Replace compressor with a re-con RM 480
Replace receiver/drier RM 180
Recharge aircon gas 134A RM 60
Labour RM 120
Total RM 840
Now I don't have to worry about hot/rainy weather!!
Hmm... you think the charge is reasonable
Why not just wire it to be permanently on? This country is so hot 24x7 anyway.
wired permanently on?
wired permanently on? >>> hahahaha.... how do you do that...? There's nothing wrong with the wiring.... but something INSIDE the clutch is not 'clutching' ON:D
I believe the function of the clutch is to protect the compressor from being 'overworked' i.e it disengaged the compressor to prevent overheating!!
