after changing break pad
sewell
Hi sifu,i have just replace my OEM disc pad with new brake pad textra ( sorry if spelling is wrong). after changing the pad i found out there is a e-e-e-e-e braking sound. when the speed at 30km/h going down to 0km/h that time the sound will be there. i ask the machanic he reply the sound will gone after a week.has anyone experience this before ?
eee sound
Bro,
U need to put some lubricant between brake pad and caliper to solve the problem. U can get it from any BMW part dealer...
Rgds
sewell;520988 said:
Hi sifu,
i have just replace my OEM disc pad with new break pad textra ( sorry if spelling is wrong). after changing the pad i found out there is a e-e-e-e-e breaking sound. when the speed at 30km/h going down to 0km/h that time the sound will be there. i ask the machanic he reply the sound will gone after a week.
The lubricant is called "copper grease". The service center apply a lot. Where did you change your pads?
for me yes, the noise gone after few weeks...., try to play with hard braking few times.., but not untill the disc got locked-up la.
Bedding in for new pads are necessary especially the hard compound ones. Textar is consider a rough pad compared to my originals that came with the car. Now I'm on OEM Textar also, supplied by SC under the BSRI program.
sewell;520988 said:
Hi sifu,
i just replace with textar as well and also having that sound. My mechanic did apply the grease, but i agree with Astroboy that its becos the pads are bedding with the disc.
Well do share with me if the noise is still there after a few weeks. I will revert in a couple of weeks when it has run in.
i replace my pad in my hometown, perak. can i know where the copper grease actually apply? over the disc or the pad?
Between the caliper and the back of the pads where the shims are. Not on the friction surface/lining la.. how to stop the car with grease between the pad and rotor? :D :D
Like this:
Like this:
thanks astroboy, i will ask my machanic to do that for me. maybe this will help
