i think ireland engineering sells a brake bias control thing.... can buy on internet...
IMO if you have bought/installed a purpose made BBK for your car, u shouldnt have to resort to brake bias thingies....
People like Brembo etc would have factored in these things when they designed the BBK for you... IMO if you follow the recommendations of BBK manufacturer u shouldnt have to use brake bias adjustment, unless that is waht they advise u to do....
Unless of course u wanna go racing....brake bias adjust gives that extra bit of control that will give you the edge over your opponents...u can also tailor yr braking performance to characteristics of the track i guess....
If purely custom made e.g mix and match brake units from different models or different makes (except people like Movit who use porsche brakes for a lot of their offerings and do their own R&D), you may need to do some research yourself and calculate the brake balance between front and rear etc to avoid imbalancing the system..
Check out this site (
http://www.bmwe34.net/e34main/upgrade/brakes.htm) where the writer actually researched the actual pound foot of torque generated at each end to get best results - see execrpt from site below :
To give an example, the E34 540i brakes develop 686 lb-ft of torque on the fronts at 500 psi line pressure; the rears produce 313 LB-ft, so the f:r bias is 69:31 (as a percentage). Adding the M5 front brake (rears are the same on US E34 M5's), which generates 720 LB-ft, changes the bias to 70:30. The '95 Euro M5 brakes generate 646 LB-ft front and 336 LB-ft rear, giving a bias of 66:34. Everyone raves about this setup, which is interesting as the front brakes actually generate LESS torque than the earlier E34 M5 (or the 540i, for that matter)! Chances are that this perception of awesome brakes has more to do with the better balance front-to-rear than the massive cooling capability, which only comes into play when you're driving the piss out of the car and the brakes are generating many kilowatts of heat. Unless you go to the track, you'll never encounter that aspect of their performance
......and all this from a guy who is still running drums at the back.....
I need to get a life ....
