Brembo brake kit to fit e46
shifter
Hello everyone...newbie here!!! Im interested to putting some aftermarket brake calipers n rotors on my e46currently i have a set of subaru sti spec C brembo front n rear brake set.Can anyone advice me if im able to fit this set up on a e46 with ease.Im sure modification will be needed. Can anyone give me some advice regarding fitting this brake set up.And the roughly the price of the mod.Any help would be appreciated. Cheers
IT would be nice of you to go to the newbee coloum and intrueduce your good self there before posting anything.Thank you.:secruity:
you will need to custom fabricate a mounting bracket to hold the caliper in place, and if your current sti disc are of the single piece setup, you will need new ones eg:- those from a 330i with a diameter of 325 x 25 mm .... should your disc be the two piece setup, all you need to do would be to fabricate new mounting hats with the required pcd and offset specification to suit your e46...
price....you will have to shop around ..
Thanks for the reply
Where is the pro shop to fit this kind of thing.?
Im sure not all Bimmer garage can do...
I Pretty sure this kind of set up is the chepest way to do
Instead of buy new 4 or 6 pot brake kit.
Any advice.....?
ThaNKs...
if u want u can give me a call 012-3666090....i maybe able to help...
shifter ...pls introduce yourself in the newbie corner lorrr...and join us and be an official member larr ...
