900hp M3
L O N G
900 hp bmw m3 700 hp (at the flywheel) with the Garrett GT30/40. GT30/40 was more than enough at the beginning. Turbo system upgraded with a bigger ball bearing turbocharger. Nowadays a Garrett GT42/51R resides under the hood of the M3. With 30 psi of boost we made 900 hp and 772 lb/ft of torque at the flywheel. Engine: - BMW S50B32 block- Low compression forged pistons- Forged connnecting rods- Custom made connecting rod boltsCylinder Head: - Schrick inner valve springs- Schrick outer valve springs- Schrick titanium upper retainers- Schrick steel lower retainers- Custom made cylinder head studsTurbocharger:- Garrett GT42/51R (800-1,000 hp depending on the compressor wheel)- Ball bearing (the same model has a non ball bearing type)- Custom made water and oil piping- Custom made turbo flange- Custom made turbocharger connecting unit- 50 mm wastegateExhaust system:- Hand made exhaust manifold: The new exhaust manifold was manufatured in 8 weeks. Stainless steel was chosen for its durability. Pipes with different lengths and diameter were welded together. At the end there is a pipe network under the hood. To make installation and removal of the manifold easier for periodic servicing, flanges at various bends of the manifold is used. - Ceramic coating of the manifold- Wrapping of the manifold- Hand made dump pipe 110 mm- Hand made dump pipe flange- Removal of the catalytic converter- Removal of the resonators- 2 x 80 mm straight piping until the rear muffler- Hand made rear mufflerIntercooler:- 1000 hp air/air intercooler- Hand made intercooler piping- Water injection onto the intercoolerIntake Manifold- Custom made intake manifold: 18,000 cc (1,104 cid)- Cold air intake located at the rear of the left front fog light- BMC Formula 1 air filterFuel System:- 3 x Bosch Motorsport fuel pumps- Surge tank in the trunk- Rising rate fuel pressure regulator- 1,000 cc Delphi injectors- Modified fuel injector rail- Braided fuel lines
That is some serious shit... 900 bhp and all thru the rear wheels! :yahoo: Can make donuts easily... :nyehehe: But wonder how is the driveability in stop-and-go traffic. :dunno: Also wondering what the 0-100kmh and top speeds are.
the car doesnt have strut bars wont there be a lot of chasis flex?
I dont think he turns. So why bother?
the interesting bit about this DA M3 is the exhaust manifold.
they took the trouble to route the turbo closer to the intake area for some gain that they claims.
some cool plumbing shit..
