mrbig;589061 said:True Qualities Of A Gentleman !
Cheers! RCBL Cheers!
RCBL;589059 said:My apologies to Mat6689. There is a dipstick!..
mat6689;588481 said:All, I have a serious problem after changing engine oil at AB. The engine is vibrating like an old engine. Worst still, if taken out the engine oils measurement stick, you can see white smoke coming out.
Checked with my mechanic, he said this could be piston ring is "burning". Checked with AB again, they said this is normal for Diesel engine (320D). Can anyone of you help me to check if your engine is "smoking" ?
mat6689;589526 said:HaHa.. finally, the dipstick is clear to everyone.....
RCBL, no mentioned. this is what the forum is for.
Anyone check whether there is smoke come out from the "dipstick" or engine oil cover ? Don't worry, you can open it while the engine is running. But, PLEASE do not floor your acceleration pedal or pull the acceleration string while "dipstick" or engine oil cover is open.
MrBig, I'm interested to know the expert who can do a good flush on engine. please share.![]()
Maniac;589961 said:found the dipstick (which i had originally misinterpreted as the coolant reservoir buoy (oops!)) i've learned something through the thread - least of which is the need to open my bonnet more often!
no steam/smoke from either the engine oil cap or dipstick for mine though. RCBL - no loss of power yet for me but still early days, running at 5000kms at the moment. Had an oil/filter change at 2000kms.
How would an engine flush help alleviate? Thinking out loud, the problem seems to have surfaced after an oil change, what could be the cause?
mat6689;590139 said:the smoke come out from my engine is not only after drove, it is when i start the engine in the morning, funny enuf, after a long or short drive, the smoke is not as much or thick like morning start.
astroboy;590368 said:Aiyoo.. why open the engine oil cap when engine is hot la? Yes, you should see vapor-liked fume, I believe its water vapor
Don't tell me u open the coolant reservoir as well when engine is hot?!!
Schwepps;590193 said:Mat, since you haven't gotten any help from the diesel bros, let me try. The above indicates that it happens more when the engine is cold, not hot. It's very easy to confuse white with blue smoke, as anything not black seems to be white. So check precisely.
What's the condition of the smoke: white with diesel smell and hangs in the air (vapourised diesel) or white with no smell and dissipates (steam)? If the former, it could be: injector problems, timing problems, low engine compression or a faulty fuel pump. If the latter, it could be a blown head gasket, allowing water to seep into the engine. If it's blue smoke then it's burnt engine oil. Your mechanic said maybe burnt piston rings, so he suspects this, caused by blow-by.
Since your engine is vibrating, I would suspect misfiring, and any of the above can cause it. Your car should be under warranty and BSRI, so why not send it in to a dealer to check? Avoid the dealer who said "it's normal" :wink:
Schwepps;590425 said:Really? I thought BMW diesels are pretty smooth and you can't tell the diff?
