You can do your own coding for your F series....if you dare.
wait just remembered, if i have a Bluetooth OBD2 Scanner, will that work ? is it the same as an eNet cable ?
It is different from enet cable. But a good base to modify and make it enet.. Do you use the cable much anyway?
M5port;750503 said:
Cafee : what have you coded for your F10 so far?
Lots of options , go through the Cheat Sheet. Cable assembly is easy dont buy.
Here's one.
[video=youtube;x9JYKmI3hvk]http://www.youtube.com/watch?v=x9JYKmI3hvk[/video]
ck318ci;750100 said:
looks complicated,
I ve visited a workshop to do the torque and horsepower dial on my idrive
wired up the car with computer and the tech fiddle with 2-3 iphones and ipad to look for cheat codes etc etc
only to find my car does not come with the module but however can set digital speedometer which I declined.
What car/model/year do you have? why not possible? interested to know.
sorry guys, was busy and away. so, can we get the heads in KL ?
CAfee : which year do you have?
Mine is Oct 2010/535i
Mine is 2012, but should be almost similar.
The cable is very important - if you can, try to at least get CAT5E or CAT 6. In some instance, you may even need to ground onto RJ45.
1) Get the Ebay 16pin OBDII.
2) Buy a proper CAT5E/6 network cable in the T568A configuration (no more than 3 metres)
3) Snip off one end of the Network Cable and solder on OBDII plug
4) 510 ohms resistors 1/4 or 1/2 watts are available in most electronic stores.
1) M5port
2) HypoGXII
3) malcolmc
4) Jason
Just added myself into the list. Hope it's not too late to join
Jason
I got three of the Odb2 connector of ebay, just need to get it solder. Then my journey of coding will start....
Guys,
Anybody managed to download the software? I can make the cables but the process of downloading all the files using Unifi is excruciating. Would be very grateful if I could copy the files from any of the guys that has better bandwidth?
Much thanks!
