funfer_fahrer
- Apr 7, 2006
- 1,928
ramsing;488528 said:fuhrer....how does it eliminate the piston wear? sounds like oil treament ala STP, Moreys etc.
Xado oil basically creates cermet to repair worn parts. There will be minimum gaps. Therefore, the engine will run more efficiently and fuel consumption improves. Other benefits include increased horsepower (I was told by Kelvin) and quieter engine. The part I like the most is lower engine operating temperature since we all know that heat is the enemy to most of the engine components.:top:
A strong CERMET surface - extremely hard and very smooth
XADO treatment creates a ceramic and metal surface, CERMET (ceramic / metal) that is harder and smoother than the original metal structure. CERMET also has a Rockwell rating of 320 (metal = 90; diamond = 420). It is not a separate layer but an intrical part of the metal structure.
Under operating conditions the CERMET surface produces far less heat and friction and which allows mechanical machinery, equipment and engines to run more efficiently, thereby: -
- increasing mechanical efficiency and engine compression,reducing friction, fuel consumption, noise, vibration and more importantly exhaust emissions.
- Extending the operating life of all mechanical machinery or engine.
XADO technology is therefore a revolutionary form of nano technology and an alternative to all mechanical repairs, which restores, repairs and recondition engines, machinery and equipment across a wide range of industrial applications from the Automobile industry to the Railways, Weapons to Aircraft, Agricultural machinery to Household appliances, boats and Lawn mowers. The list is endless.
An unique advanced engine treatment for the 21st Century. No other engine oil additives compare
