WTS: M54B30 strokerkit
Mtigo
Official Member
Hai,
I have almost complete 3L strokerkit for sale. Item can plug n play to M52tuB25, M52tuB28 & M54B25 engines upgrades.
Stroker kit consisting of:
1. 6 x M54B30 piston c/w connecting rod - SOLD
2. 6 x M54B30 fuel injector c/w fuel injector
3. 2 x M54B30 camshaft
4. 1 x M54B30 crankshaft - SOLD
5. 1 x M54B30 intake manifold c/w CCV, Disavalve and also will give throttlebody apadter plate
I'm looking for RM4k nego nipis.
If interested can watsup/call zero0ne8double6zero330i
* This upgrade can be done at vixx customs.
Mtigo,
You wrote that the kit is working for M52TUb25, so could you please confirm the difference between the the blocks of M50b25, m52b25 and m52TUB25: I've heard that the 3.0 rotating assembly touches the cylinder wall (with the rod) in m52b25 block and that it does not touch the cylinder wall in M50b25 block... but I am not sure if it does in m52TUb25??
I'm planning to put a 90mm crankshaft from m57B30N in my M52TUB25 block, and I'll be gratefull if you can tell me if the m54b30 rotating assembly works in my block without any modifications to the block??
As mention above, Item can only plug n play to M52tuB25, M52tuB28 & M54B25 engines only
bro, what about m54b25 smg gearbox..?
still no problem to upgrade to 3.0 stroke kit ...?
im newbie about bimmer, glad if u can help... :)
