[WTS] Gearbox, Strokers, Cams, Calipers, LSD for those who want more out of life :)
ramsing;641838 said:
Got some nice stuff for sale. Price is negotiable. PM me or call 012 2206387. no SMS pls.
M3 ZF 5 spd gbox + clutch/flywheel + E36/39/46 original longshaft + gear linkage - RM7.6k. (E36 buyers will get transmission cross member) 2 out of 4 sets SOLD!!!!
E34 M30 5 spd box + clutch/flywheel + E34 original longshaft + gear linkage - SOLD!!
Torsen LSD for E30/E34/E36/Z3 188mm diff - RM1.9k
E46 330i front+rear calipers + new rotors - RM3k
E46 330i front+rear calipers + used rotors - RM2.5k
US 3.2 S52 cams - RM2.5k (includes chip for Bosch 413/506 ecu 2.5, 3.0 and 3.2 cc) 2 sets SOLD!!!
US 3.2 stroker (crank,pistons,rods) - RM5.8k
US M3 3.2 E36 ZF HP518 auto gearbox - RM3.0k. Does not come with wiring or ECU. As its from a 3.2 M3, the gearbox should be rated for higher hp/tq. Fits E36/E34, if you already have the wiring and ecu.
coming soon:
- E46 M3 6 spd gbox + clutch/flywheel
- E46 M3 longshaft + rear LSD diff + driveshafts + rear M3 subframe to mount diff
- LSD for E49/E39
- 1 set of manual 6 speed V8 gearbox + longshaft for E34 or E39 + rear diff LSD and 3.15 gearing + shifter linkage (only 1 set, so you can reserve with a deposit if desired)
boss, nak tanya, is e34 24V 188mm rear diff?
tehyw;646277 said:
vincent leh?? he need v8 GBox...
hehe...manual for 7 series? following the footsteps of transporter part 1?
should be 188mm. y, lsd got ur saliva dripping?? hehehe... lsd + 3.15 gearing. yum yum
E30 owners, what have you done lately for your E30? Time to put some TLC and give it a nice spanky LSD diff. Pamper your baby, and it'll kick its tail out for you :)
Now available rear diff for E30 models. Diff with Torsen LSD and 3.15 gearing. Normal LSDs are clutch type, which wears out eventually. Torsens do not wear out, and is smoother in engagement.
Plug and play for E30 models, you can either tarpau the diff in the boot, or drive in-swap-drive out. Price is RM2.7k, without installation. Installation should be an hour or two, if appt made beforehand.
u r so bad !!!!!!!!!
Lionel_Koh;648754 said:
aiyo .....got super duper sales ah ?????
hahaha..for you sure got. but u have to give me first ride in your monster when born :D
update also on the strokers. price reduced.
Million thanks to ramsing for the deal of the E46 330 calipers. Now sitting very nicely in my car.
Cheers =)
Cheers =)
enjoy the brakes :) I think you need a LSD soon.. :D :D
got some new items,
E39 M5 manual conversion.
E34 6 spd V8 manual conversion
E46 330i 6 speed manual conversion :)
refer to first page.
ramsing;655675 said:
got some new items,
sorry noob question, can the manual conversion (e46 330) be done on smg? current 5 speed not enuf la
Dei lamsing......your racun is of a different league la....this la having IndoSiamSinoPinoy...all things that make me go OHHH LAAAAA LAAAAAAAAAAA
sure...wont be an issue. Y 5 speed not enuf? trying to hit 300km/h? :)
hahaha...u faster sell ur M3. Then I will give you orgasm on wheels. any gears you can do burn out :D :D
bro ramsing,
Gatal to know if the e46 330 6 speed manual conversion can fit in my e46 325 M54 ah?
shasall;660057 said:
bro ramsing,
hahaha...can, y cannot? its from E46 chasis, so of coz it will fit. then u will have 6 gears to play with everyday. oh, plus 1 gear labelled 'R' for racing! :D
That R is for reverse, as in BELAKANG MAIN...
ramsing,pls advice me,i'm driving e39 523i 99 model double vanos,2500cc uk spec,wanna upgrade this engine to get more power,performance,wanna manual gearbox,n advice me what parts some more to make my m52b25 powerfull,or just change tu m54b30 n manual gearbox, really wanna do this project if can b4 raya....pls advice me,what to do n the most important costing
wow. so many monsters in the making :) what I would recommend, if your current engine is still in good conditions, is to do the manual conversion first. then later, you can decide to stroke, or add supercharger or turbo. most value for money would be forced induction, ie turbo/supercharger.
you're in luck. if you're really serious in converting b4 Raya, I might have all the parts now for the conversion. should be enough time to do it b4 Raya. but you have to confirm by tomorrow. call me if you're serious, my number is on the 1st page :)
