ramsing;641838 said:coming soon:
- E46 M3 6 spd gbox + clutch/flywheel
- E46 M3 longshaft + rear LSD diff + driveshafts + rear M3 subframe to mount diff
- LSD for E49/E39
- E36 ZF HP518 auto gearbox
pussy;643507 said:saw the stuff today... manyak cun... the M3 gearboxes are so new...somemore with the vin encoded on it...
seewai;643522 said:Bro can give sneak preview dulu kah, of spec for item in bold merah? eg ratio...
ramsing;643631 said:i heard u ordered one manual V8 box for your E32. since your autobox dying, good time to swap in a 6 spd. highway monsta soon to be born!!!!!
loafer;643793 said:Your new hobby is growing spiders in gearbox izzit? Put under the bed for what get it installed la![]()
pussy;643897 said:sshhhh... waiting for the 4.4L block..hehehe..
hehehe....so far nothing to show yet. but if it happens, ratios will be around 3.15 +/-for auto's, most prob will use back the auto gearing
wanganstyle;643983 said:Manual Trans e32 is almost as good handling as E34, Better stability @ Wangan speed too!! With G420 6mt Fit a 3.15-3.23 Final in either 210mm or 188mm to push the wind![]()
Tires will be smoking.....1-2-3 shifts, E34T 4.4 6mt+3.15 210mm LSD can Choku-Dori at pedestrian speeds with easy modulation on sheer torque. E32 with same setup will be even better!
Miller has tuned 4.4L M62+g420 obd1 himself (that we swapped into an E34), the cam is not as happy on top end as the M60b40 setup though. Stock 3.0/4.0 ECU mapping with 4400cc is a bit off, runs lean in places.
There should be a OEM cleaner way to do the crank position sensor adaptation (than welding bracket on timing cover or playing games between single/dual timing chain) for OBD1 DME also...........secret sauce![]()
pussy;644453 said:that LSD fitted on that car, very torquey now...somemore on a 4.4L....
ramsing;644381 said:I already ordered your 4.9 stroker kit for the 4.4 block. Along with the 292 street racing cams. Should make your E32 a nice little monster!
yes, totally agree with you. V8 manual will be a highway monster. Along with some nice tuning + cams, powerband all the way to the top.![]()
Green Bimmer;645894 said:i also have i spare ZF5 HP 18 under my bed.
pussy;646057 said:i too have many many gearbox, under my bed, my store and my maid's room...now no place, cos V8 pistons and crankshaft in my wardrobe... hahaha...
