White smoke is not persistent but actually during rev. My engine oil have to top up every 3KALIAS said:Bro Fuza, what's your mileage like? Is the white smoke due to condensation or you actually have a leak? In other words, if it's a persistent thing (not just when engine is cold), then you probably need that top overhaul. Have you done a compression test to confirm it?
hi moots, mileage 90k. I dont think its major. I was told that I have to change the valve seal due to engine oil consumption.moots said:bro ...e90 already top overhaul?wat's yr mileage?
magpie;n1326959 said:bro,
I also notice white smoke only when the engine is cold and especially on a cold day (after raining). my mileage is around 44k. Is this the same problem as Bro Fuza?
ALIAS;n1327026 said:from my understanding, if it's only when engine's cold but clears up when engine's warm, that's due to condensation. not a cause for concern. must also look out for coolant loss.
