What is this black box for?
johnj
Founding Member
I recently changed this black part in my 39 M54B25 DV. Can someone tell me what this is for?
bro, whats the result after changing it n what caused u to change it le?
My ride dont have lah..
I'm not sure about the result but it had a rattling sound. it has a butterfly kind of flap with spring action but the faulty one no spring action at all..
I changed mine too...called adjuster unit...it's meant to open at high rpm, helps in FC and acceleration. How it technically works, I dunno....mine didnt' hv the spring effect anymore and flapped...after changing, had better acceleration, but didn't notice much on FC differences. I think this is in M54 engines, not 100% sure though..
Read this in another forum :- http://forum.e46fanatics.com/showthread.php?t=342081
Another simple DIY to learn I think...
Last week while sitting in rush-hour traffic I noticed my car was idling terribly. The problem was traced down to an adjuster unit in the intake manifold that had broken. $206 in parts later the problem seems to be fixed. I can't say this is causing everybody's problem, but based on the part and the problem I believe it is prudent for all fanatics to check this part on a regular basis. Details follow...
Car
2004 330Ci, 04/2003 Build, 86,660 Miles
Manual Transmission
New Bosch Coils installed around 50k Miles
New Spark Plugs installed around 80k Miles
Symptoms
Initially the car was idling roughly and the MIL (aka CEL/SES) light was off.
Car idled roughly regardless of cold or hot.
When the MIL did trip the codes were as follows
Misfire - Cylinder 1
Misfire - Cylinder 2
Misfire - Cylinder 3
Misfire - Cylinder 4
Misfire - Cylinder 5
Misfire - Cylinder 6
Misfire - Multiple Cylinders
System Too Lean (Bank 1)
System Too Lean (Bank 2)
MAF Sensor (can't remember the exact code)
Diagnosis
* Since the MIL originally wasn't on when the problem started, I took the car to a shop to have all fault codes read.
* The mechanic at the shop found the adjuster unit was broken, but was convinced the problem was vacuum-related.
* Mechanic tried other diagnostics, such as moving plugs and coils around, with no luck.
* It was getting late so the mechanic pulled the broken adjuster unit flap out of the intake manifold and put the adjuster unit back in.
* While driving home the "System Too Lean" codes were set. These did not happen while the car was in the shop.
Commentary & Lessons Learned
I still don't have a definitive understanding of what the adjuster unit does. However, based on the location of the part (the flap portion goes inside the intake manifold), I'm guessing the relative position of the flap determines how much air the engine gets. When the mechanic pulled out the broken flap, the unit was left wide "open", which I'm guessing caused the "System Too Lean" condition.
After inspecting the broken flap and the unit more closely, I noticed there was significant dirt build-up on the parts (see picture). I'm guessing over time this build-up eventually started restricting the flap's movement. Since the flap is connected by a plastic connecting piece, the excess build-up ultimately caused the plastic connecting piece to break and the part to fail.
I drove the car for several miles today after repair and noticed that the idle was smoother and also the throttle response was quicker. I believe prior to the part's failure the adjuster unit flap's operation was still restricted which caused incorrect air/fuel mixtures to be running through the engine when engine speed was changing. For example, RPMs tended to drop more slowly before the rough idle problem appeared.
Based on the amount of dirt that was on my adjuster unit, I believe this part may be responsible for more than just rough idle problems (and possibly stalling on steptronic cars). Since the adjuster unit is a physically moving part, there is no easy way for the computer to know that it's gone bad, other than throwing other errors. The adjuster unit is a fairly expensive part ($200), so it would probably be a good idea to pull it out every Inspection to inspect and clean. Also, it appears there is a small metal pin holding the far end of the flap, if the adjuster unit fails it's possible this small metal pin will end up somewhere in your engine. Preventative maintenance of this part is key.
EDIT: Looking closely at the second picture, it looks like the adjuster unit is made to be able to close 100%. With all the dirt deposits on the second picture, it looks like the adjuster hasn't been fully closed for a while. This might be causing some of the intermittent idle problems. Just an afterthought...
DIY Notes
Removing the adjuster unit requires two T40 Torx screws to be removed and then the unit can be pulled straight out. However, due to space constraints I recommend removing the airbox to allow you to push the intake hose down to give more room to remove the valve. When you pull the unit out you will have to angle it slightly upwards to remove. Installation is the opposite of installation, you will need to insert at an angle to get it to fit, it helps to hold down the intake hose.
The DIY Disclaimer
It wouldn't be a DIY without one! I make no warranties to the accuracy of this information or my commentary/beliefs nor do I take any responsibility to update this information should additional details arise. I take no responsibility for any problems you run into for following any of this information. If you are uncomfortable with working with your own car please seek advice from a professional mechanic.
That is the adjuster valve , proper German name is DISA (Differential Air Intake, something like that). When at low rpm the flap is closed (charged) for better torque. Goggle DISA , you will get lots of videos and info.
There has been catastrophe when the pin holding the flap broke and got sucked into the engine causing great damage.
Older generation engine than M54 also has DISA valve.
Bro John,mind to share how much you paid for the valve ?
NO problem, I have a pdf explaining details (Vanos, DISA etc) of the M54 engine , I can email to you if you want.
this item is the air intake adjuster unit. it adjust the amount of air to be mix with the fuel. Air & fuel mixture if this fails you consumption will be be very high. It functions together with the MAF sensor.
One way to test the DISA, [video=youtube;s82CIF28zhU]http://www.youtube.com/watch?v=s82CIF28zhU[/video]
I think the adjuster unit in my car (E46 325i) is defective as well. Noticed there is a slight tapping sound when accelerating at low RPM and the acceleration power has degraded a little. However, no symptoms were felt at high speed movement and high speed acceleration.
Anyone know how much the adjuster unit for a 325 costs?
hi guys...mine is e46 325, been told by my fren had a adjuster unit problem too. i noticed everytime when my car is almost stop, my l/100km meter is gone up eventho i didnt press the paddle and then slowly went down after few sec. and also my rpm meter is not stable every morning (warming up engine) and its caused a slight shaking on the engine. is this 2 problems caused by the adjuster unit?? how much is the adjuster unit?? thanks
