mini_jeff67
- Dec 14, 2004
- 2,017
Hi Sifus and Sifuettes,Happened a few days ago, off and on, no particular interval - the lights warning light (the one with the whole car) comes on with the right rear lamp lighted in the middle of driving, then off again after a few minutes. I took this to mean that either the rear driving light or the brake lights is faulty,but when I stopped to check, both were working fine. :unsure: Popped the boot to check the casing - was OK except little loose. So far has not happened again, so I suspect it was probably just the casing being a bit loose.Any other possibilities? :dunno: Comments and advice appreciated! :yes:
