Chris2000 reporting in.. hehe...
My leak just got worst..
Top up on June 2nd and exactly 5days later on 6th June warning light came on and i need top up again.
This morning to work, as usual park my car nicely then took some stuff to off then went back out to my car to take more things and to my horror, front passenger side all my green coolant flowed out all over my front bumper and wheel!!
Hai, called my mechanic friend, he said need to check 1st and he suspect the radiator casing crack like what ylkhor said..
So finally sending my car in to check leak + change all necessary rubber hoses + repair top oil leak + replace transmission oil/filter/gasket + replace rear axle oil + replace power steering oil + replace brake fluid oil.
will keep you guys updated on a detail maintainance job + items + cost + any difference with the oil changes...
