integramania
- Nov 21, 2006
- 665
Hi Guys,
Any one experience before when cranking the engine it doesn't start up? Usually when car is left idle for a few good hours? But can start up after leaving it a while? Battery is new...When I turn on the key, I can hear the fuel pump.
Issue is also intermittent. Usually when car is left for a short time say 4-5 hours after initial start up its ok. But left overnight or more than 6-7 hours this problem occurs occasionally. Is it the starter or crank position sensor or fuel pump fuses?
Thanks
Thanks
