Tire Sealant
boy
Any idea where i could get tire sealant. Where you spray it inside the tyre and than mount it. Its supposed to prevent from any air leakage. It can be used in any air filled tire. High pressure, low pressure, high speed, low speed, tube or tubeless(it is more effective in tubeless tires). * Seals tread area punctures 1/4" and larger in heavy ply tires. * Seals rim and bead leaks. * Maintains tire pressure, and lowers tread area temperatures. Thanks guys / gals
Actually the application is to mount the tire before insertion of the sealant. If you need the contact pm me.
