TireCare Permanent Sealant
Club Vendor
- Jan 7, 2016
- 66
1. TireCare Sealant and air compressor is a separate items. Example: After you inject the TireCare Sealant to a punctured tired and we had provided you the tube injector. After you use the tube injector. You just need to use water to wash the tube injector. TireCare Sealant formula only react the tire. It will not blocked your valve or valve core or the air compressor head.Deep said:Excellent, now comes the million dollor question.
After the compressor is used to pump in the sealant into the tire, there will be some sealant leftover in the tubings/pipings of the kit. Then the kit is stored in the car trunk by the consumer. Months later when the consumer wants to use the kit again with a new pack of sealant, the leftover has dried up and blocked the tubes and so the compressor kit cant be used.
In this case, how do u ensure this does not happen?
Sent from my GT-N7100 using Tapatalk
You can drop by to our office and we can present a demonstration to you. If you got any doubt please feel free to send us the enquiry.
Thanks.
