The Black 5 | Update: April 07
Tom,
Saw ur car at the Hulu Kelang highway yesterday evening,nice ride bro..Damn garang when u were behind me... Had to give way of course..hehehehe... nice ride..
reedoor:
right, Melodies is really near. use to hang out at the caltex area pretty often. nice place. nice highway too......
Jerman: thanks!
Angelicdemon: Thanks, Not really, Interior is really stock , fabric interior, except for the headunit, Mtech II steering and AC Schnitzer replica pedals..
need to hide them with black window tint :)
525i:
Rubbing:
Not when going straight fast or slow, or going on low or highspeed corners
But since the car is so low, they REALLY rub when:
[TAKE NOTE: ONLY Because it's pretty low now. or else, it should not happen. so don't worry if you're planning to widen the track]
-Fronts: Turning into a uphill driveway, so you have to point the car into an angle and drive striaght up, if not, the bumpers will get some
-Fronts: I discovered yesterday that they rub even when taking downhill corners at Gentings
-Fronts:
-Rears: When you go over uneven roads at speeds (but pretty rarely)
I've rolled the rear fenders. But not the front. will be doing them soon. so it'll solve the probs.
Handling:
The car feels good and it feels more planted. But what's also important is it looks better.
Spacers:
They are aluminium, with hubcentric rings.
They slot onto the hub sandwiched by the wheels bolted on with custom new bolts. longer bolts actually.
i use to use bolts from Mercedes cars for my 12mm spacers on my E30 as they're longer than BMWs. I'm not sure if they can take 15mm spacers. but i bought new bolts for the E34.
Supafly:
Yes, only the rear. haven't done the front yet..
I must. i've kind of damaged my front fenders a little already.
Anakin:
They're alright.. I went to them because i know them and because i wanted coilovers. If you want something more high performing and higher quality and much more convincing, i suggest you go for the more popular brands like Bilsteins or things like that.
Titans are not dirt cheap either.
andy:
You did?
What time? what were you driving? were you in a Silver E46 coupe with the ACS wing and tailpipe? wanted to say hi to you but i was on the phone waiting for directions..
Thanks
If you were, that's a tasteful one you have.
Tom,
how much is the 15mm spacer? is thr any diff between spacer for e30 & e34?
reedoor:
it cost me RM400 for them. of course, the E30 is 4 lugs.
One significant point you should note is the center bore of the wheel you're fitting on. the spacer has to to sit into the hub with precision and the wheel's center hole has to sit into the the spacer's hubcentric ring as precise as well. or there will be vibrations at high speeds.
Andy: will see you again someday
woi .. change enjin laaa ... can tarik meh .. (i know laa what u are doing .. u dun want to share-share aaa ..)
of course i want some muscle in there like what you've got.
I want the one you just got for youself.. but an M30 will be good enough for starters..
Ni 535i, racun tak racun.... whaddaya have in your M5 wannabe now? A V8?:D
As for me, I will stay in the "baby" league for now....:rolleyes:
Tom, nice car you have there. Too bad I missed the sale of your rear lights. By the way, how much did it cost you to install the Titans? Had them in my ex-E36. And how much was the drop? Am thinking of dropping my ride....:cool:
Rear lights - with the BIG SICK
TITAN - 2.5K - that's what he quoted me
Pillow Ball - 600
flash
it's pretty much the lowest i can go for now.
all wheels are tucked. so unless i hack the fenders a little more that's about the lowest i can go..
thanks guys!
rezzy: E30's still in the workshop :)
We bring you this post for an Important announcement...
Goodies worth Rm80K is up for grabs and a Lucky draw prize to die for (literally if it does a Titanic) so pls do register for The Annual Dinner thats goin to happen on the 16th of September and be part of history...
wow tom! had no idea you still had the e34! i like the updated look! awesome job on the wheels! i miss having a black e34! :( come visit us on bf.c sometime!
Wow, someone's got an E90 now! Never expected that :)
So what is it? a 330i?
