geoffrey318
- Feb 15, 2005
- 36
any sifu here can let me know what's the function of the temperature sensor inside the afm??
absidian;220819 said:1. O2 sensor is not used by ECU when engine is cold, as this takes time to heat up in order to provide correct readings. On cold start, engine relies on AFM, temp and TPS to tell it what to do.
2. Typical idle problems... could be ICV, vacuum leak, intake leak, AFM, etc etc.
But if your car runs prefectly fine when hot and on the go then I'd rule out 02 sensors.
geoffreylee;220803 said:2. Engine is smooth (850rpm) on P or N but when shifted to D or R engine vibrate as RPM drop 200rpm (650rpm) when gear is engaged. Normally the rpm will revert back to 850rpm after the gear is engaged.
K.M.;220989 said:I have this problem too. Some people said it's normal for auto car. But I don't think so. No time to look at it yet. Thinking of sending the car for full engine maintenance or just upgrade the engine.
jarance;221063 said:Please check your ICV. The ICV control the idling speed.
K.M.;221179 said:I don't think it got to do with ICV. ICV is for the idling. As Geof mentioned, the vibration only occur during when gear is engaged, not during idling. When the gear engaged to D and R, the engine rpm drop to around 650rpm which created the vibration.
The thing that need to be find out is what had caused the engine rpm drop when gear engaged to D and R???...only then can solve the problem.
