Steering Vibration
rx7soo
Hi, EveryoneDo anyone experienced b4 whenever ur car stop moving it seem like a Vibration on de steering n u can feel it on de sitas well. Which i have changed my lower arm bush, did my on wheel / off wheel balancing. problems is still thereFYI: car model: E36 318(M)could anyone tell me wat are de problems, wat are de parts tat i should look for to fix it.Thank you.Ur advice will be appreciated
Originally posted by rx7soo@Jan 13 2006, 10:17 AM
Hi, Everyone
as well.
Thank you.
If, as you said, "anyone experienced b4 whenever ur car stop moving
as well", then why do you link it to bush and wheel balancing?
Please clarify. Are you feeling the Vibration when you car is moving or stationary?
If stationary, engine mount, engine balancing, uneven compression across the cylinders, etc.
If moving, it can be a whole host of things.
Please give more precise info.
mm... i am facing the same problem when i stuck in a traffic. told by M-speed that my engine mounting is a palsu 1, so maybe u can check with ur mechanic about the engine mounting. :)
thank you bro...
will try check it out...later...
hopefully will not be too expensive to fix it..;)
