bmw7833;700908 said:I solved my klok klok sound after replace the D-bush which holding the anti roll bar. U can give it a try as not an expensive items.
bimmerholic;701195 said:As for BMW7833, he replaced item 2 based on his description.
As for b33mer, i think it's item 5.
Correct me if i'm wrong bro.
Nvm, this coming E39 TT, i'll let you have a go in my car, then can verify if it is the same sound you had in yours.
b33mer, do join in for the E39 TT, here's the link: http://www.bmwclubmalaysia.com/forums/showthread.php?45685-E39-TT-MMZ-Bukit-Jelutong/page4
B33mEr;701274 said:spot on bro :top:
Sure arr can join the E39TT nanti takut kena halau pulak hehehehe... :4:
bimmerholic;701311 said:Haha...no la mane kena halau punya....if anything also, with your B30 & SMG & Power-2-Weight will halau us out hehehe
dancch;701585 said:Finally replaced steering top U-Joint, no more knocking sound, feel solid when drive thru those uneven/paving road even with high speed.
dancch;701762 said:Initially replaced item No.4 but ended up have to replace item no.3 also, to solve the whole problems, the damage cost around rm1k inclusive of labour. it adviceable to replace this two items together at once.
polaris78;703037 said:Hi, are you changed the new one? I just changed 2nd hand steering coupling from chop shop cost RM200 excluding labour.
