yee7402;533970 said:Hi! Can anyone tell me what would be the difference in terms of driving dynamics by having staggered and normal 4 the same wheel?
What are the pro and cons?
Thanks
jasonnn;534047 said:Staggered
Pros:-
Looks good, wider rear wheels.
Cons:-
can't do wheel rotation.
B33mEr;534053 said:^ Uh bro ... since when anyone said staggered set-up will improve handling???
jarance;534057 said:maybe because wider wheel base at the rear..:smokin:
yee7402;534051 said:Ah! Suddenly got some quick response.. haha.. Thanks all... Am currently on 18/40/225 all round..planning to change my rubber in 2-3 weeks time and toying with the idea should I increase the rear...
Am planning to reduce from 18-17 due to harsh ride on the 18..
Will consider the 17 and staggered first than since it was mention that it will improve handling... Wonder by how much and what would the fun factor amounts to..
yee7402;534114 said:Thanks Mizhan
so out of curiosity is the E46 325 consider a vehicle with a chassis optimized for a staggered wheel setup? I know the M's are but what about the normal ones..
astroboy;534142 said:Looks aside, on the practical side, the only reason for a wider rear tyre set up is when u take off, u have too much rear wheel spin, have problem biting the tarmac, so u put wider rear tyres.. or when cornering, you have serious over steer problem, so u put wider rear tyres to gain extra grip. In other word, for a 6-potter BMW, most of it comes with stagger set up because if not, the rear tyre wears out fast due to its power, which drives the rear wheel.
I doubt any one would notice u have a stagger tyre set up. Many just play with rims with stagger look (different offset), yet mounting with same width tyres.
I don't like stagger tyre set up because the car is very nervous in the wet. When front tyre roll over wet surface, it actually disperse water and create a less water path for the rear tyre to roll over. It works fine with 4 wheel equal width tyre set up but when u have a wider rear tyre, the path cleared by the front tyre is not wide enough for the rear tyres to roll over, so the rear tyre has to work harder to thread water, the car felt nervous when this happen.
