Some parts question in e39 before i start DIY
Can i still drive the car if the aux fan failed to rotate now? The aux fan failed to move at all even i switch on the ac in hot day.
I have to drive 100km from my current location to workshop, otherwise have to tow. What is the damage to my car if i drive the car without a working aux fan?
kayzhen911;607858 said:
bro 7833....
change ur car la.
hehehe....
niabeh..u tot i am you meh? Can change car so easy.
I do love my car so much la, don't try to divorce us.
You can still drive when aux fan not working but switch-off the air-con to prevent overheat. Possible damage: engine block crack, other internal parts crack and the list goes on.
Even if i can maintain the temperature gauge in half?
Yes, temp gauge 1/2 is normal. To be safe, just switch off the air-con. The clutch fan will keep the engine within the operating temp.
Thanks bro.
I will drive there tonight, hopefully the engine temperature does not go mad.
Where is the fuse #75 and #76 for aux fan located? I can not find inside the glove box. Even i check in the E box under the a/c filter housing also no see. Can anyone point it out which one is aux fan relay?
This is how the cable tight in the E box:
Under the yellow circle still have 5 relay, which one is the aux fan relay? How to check? I can only see the top right pink color one is ABS relay.
eehhh.....aux fan not running with the belt ? is running electric ?Is the aux fan is the big fan which use to cool down the radiator ?
artz19;608027 said:
ahh the e39 a good car but lots of problems
Nope, u are wrong..just i like to DIY 1st before throw all the problems to mechanic.
Please substantiate your above statement.
Are you driving a e39 and if so, what were/are your problems?
Found out he like to bullshit in some thread. Keyboard warrior?
Yup all BMW model are sucks but I like to Jilat BMW because they make me cum all the time.
My problem is that the love for BMW keeps growing everyday..
Bang sudah jilat jgn lupa hisap lagi... baru enak tu. Ha...ha......
aiyah, don't spoil my thread la..mau jilat mau hisap, pegi tempat lain la..
moots;606732 said:
remove the connector and find the ground wire - shud be brown kaler.short the other 2 wires,one at a time,to this brown wire.one shud be lo speed and the other,hi speed.
Bro, i try this afternoon to check the fan motor..no moving at all the aux fan.
Check by mechanic and confirm the aux fan gone. Instead of changing the whole aux fan, where to buy the aux fan motor here? The price for the whole aux fan and the motor alone is big different.
The aux fan motor looks like this:
Aux fan motor (Siemens) not available in M'sia. If you just replaced the aux motor, your current plastic plates may already be brittle and may crack later on. Suggest you replaced complete set of new ori aux fan (with bmw logo @ RM 1,450.00). Don't buy the cheaper aux fan (Taiwan made) as it does not last.
