Small problem ?
jumpman
well..i just found out that this happened to my car (refer to pic) will it cause anything to the car? how much would it cost to get it replaced ?
If thats the plastic cover under the front mudguard, that cost nothing if thats what you are refering, I did change new one and cost RM65 as mind broke at the screw area I just can'nt see damage so check out with parts shop they had the stock buy it. good luck to you.
it's the front air scoop cover, should be easy to rectify.
either buy new or get it from the chop shop
hmm..how much wud it roughly cost ? is it ok if i leave it as it is for the meantime ?
yeah u can either get a new or used replacement unit which is easily available.
not too bad a problem.....
anything sms/call me okies!
rgds,
-brad-
what are you refering to?
