Just two days ago, my left hand signal light is blinking much faster than normal. The right side is okay. Anyone have any idea why this is so? Perhaps I accidentally turned on the signal speed (is there such a thing?) Please advice.
IF all the 3 light all ok, can be the wiring sortage..happend to me when my car was repaired after accident, all the light blinking ok, but its fast. AB rectified it (after all the fights)
Turn on your hazard lights and see which signal bulb is out. If all are blinking, dismantle the entire left light assembly and check for bulbs that are blackened but still working. Change them. Next, dismantle all bulbs and check for corroded contacts.
Also check the power connectors. If you see one of pins is melted then you can try to repair it, or in worst case,you have to replace the entire thing. Mine was partially melted but my dad managed to revive it. This melted pin is a sign of internal overheating in the signal circuit. To be on the safe side, install another ground for the entire light assembly.
