Secret Menu for Instrument Check
yan
Member
Check your instrument !!!NOTE: Just for the hell of it. KLR means ignition switch position #1 (accessory) KL-15 is ignition switch position #2 (on), and KL-50 is ignition position #3 (start)This works on all instrument clusters 1992-1999 E36 - 4 door/coupe/convertible/M3.Step 1. Press and hold the mileage reset button.Step 2. Put key into ignition switch and turn to KLR (Ignition switch position #1)Your LCD display will show something like this "tESt 01"Step 3. Once "tESt 01" is shown, let go of reset button and the IC (Instrument Cluster) will go throughsome test cycles. Numbers will be shown and here's what they mean:1st display: BMW PART NUMBER (6 digits)2nd display: CODE NUMBER (5 digits) Internal Coding Plug #3rd display: K NUMBER (4 digits) 4th display: CHASSIS NUMBER (5 digits) this is part of your VIN5th display: SOFTWARE VERSION (3 digits)6th display: REVISION INDEX (2 digits) Hardware #After all 6 displays are finished, an analog gauge test will be performed.The self-test is canceled by switching the ignition off or to KL-15 (ignition switch position 2)IC (instrument cluster) tests 1-151995 - 1998 (99) 318ti1996 - 2000? Z31997 - 1999 E36 4dr/coupe/convertible/M3NOTE: *Test functions 1-4 are unlocked tests and can be called up at any time for display.*Test functions 5-14 are locked and require unlocking the test mode before they can be displayed.*Test functions 2-14 can be selected at any time when the cluster is unlocked, even when vehicle is moving.*Test function 15 is the lock/unlock function.Step 1: Press and hold the mileage reset button.Step 2: Put key into ignition switch and turn to KLR (Ignition switch position #1)Your LCD display will show something like this "tESt 01"Step 3: You will need to unlock the test function first so when the LCD Display shows "tESt 01," press the reset button till you get to "tESt 15." Once you're on test 15 press, and hold the reset button for a few seconds until it displays "off." Now you can cycle through the test features. Here they are as they follow:Test 1: Instrument self testTest 2: Engine Data - This display is an "engine factor" value that is stored in the coding plug. The instrument cluster processor uses this factor in addition to the "TD" signal from the DME control module to process and display tachometer RPM based on the engine installed. For EXAMPLE:*ENGINE FACTOR 2 = 4 CYLINDER*ENGINE FACTOR 3 = 6 CYLINDER*ENGINE FACTOR 4 = 8 CYLINDERTest 3: SI elapsed distance - the total mileage in kilometer since the last reset. Which service is due at the next inspection (OIL SERVICE or INSPECTION)Test 4: SI elapsed days - no value for US vehicles. Relates to Euro annual inspections.Test 5: SI evaluation factor - for engine speed and temp. thresholds being passed. Display: n = 0 or 1. Engine speed (over-rev)t = 0 or 1. Engine temp.NOTE: "n0" means that you hit the maximum threshold for engine speed and "t1" means you overheated the engine. I found out from my instructor that this test 5 is false due to software related problems. Test 6: Fuel Level and coolant temp. - Display of hexadecimal codes in relation to gauge position.Fuel gauge ----> Hex valueA (empty)---------> 0dEnd of reserve---> 37B-------------------> 54C-------------------> 90D------------------> c4E (full)-----------> f0Engine temp. ----- Hex Value A----------------------> ce B----------------------> 6dC----------------------> 5cD (center)----------> 4f-23E-----------------------> 1eF-----------------------> 18Test 7: Engine speed (Digital Tach)- display of current engine speedTest 8: Road speed - display of current road speed in km/hTest 9 Distance reading - this allows the total stored mileage to be updated if one of the storage components has to be replaced. This test step will be used if the manipulation dot is illuminated in the cluster display. This display will show the component with the lower mileage. For example:Display of 012654 l indicates that the mileage in the internal EEPROM is lower than the mileage stored in the coding plug.Display of 000325 E indicates that the mileage in external coding plug is lower then the total mileage stored in the internal EEPROM.Pressing the reset button for 4 seconds will over write the lower mileage with the higher mileage and cancel the manipulation dot. The SI data will also be transferred at the same time.Test 10: Status bits (input signals) - the status of digital inputs to the cluster are displayed as 0 or 1.Display: 0 = input low, 1 = input high._ _ _ _ _ _
Originally posted by lipisbimmer@Nov 11 2005, 10:50 AM
is it applicable for e36 only ke?
other models how.... e.g. e34 :wink:
Actually, it also work for E34 as well.
i have try it on 2 of the forummer's e34 before and it works as well.
wokeh sifu... thanks.
i'll try that... :wink:
