Screechy brakes
just share my xperiance... ive change to Brembo rotor recently, and use oem pad... still squeking... very annoying...
Brembo rotors locally? Most of them are not original I believe.
Galaxy7;663204 said:
yes, mine also at slow speed.
Accumulation of brake dust can also contribute to squeking of the brakes :4:
Agreed..start driving after being washed in the rain can aggravate the issue..screeching braking sound is unbearable sometimes..but it disappears after some distance, at least to my car..IMO
well, i guess so... i hope mine is ori... even tho it singing while braking... hahah
I have been using ori BMW brake pads & disc rotors and also no screech noise. After using for more than a year, last week put in new Zimmermann drilled rotors with BMW ori pads.
Me too....And its getting louder and louder. But ones rain....Not squeking reduced.
haywire;665669 said:
Got all new ori BMW brakes, no screech whatsoever....
mmm...so the ori one no squeaking compared to oem. will change mine to ori also la next time. thanks for the info.
The original ones might also cost more than doubled compared to OEM :)
well... just so you guys know... bedding or not (or brought to bed :p) is somehow not related ...
I just got a slap on my intelligence when i use TRW brake pads...
I got this squeak in low speed and metal tapping noise when i go over gravel... i complained to the mech and all he say is this
"Lets bet RM 300... you sign the pads and rotor so you know i dont change them"
Then a couple of hours later he ask me to drive... just after he install back all the rotor and pads... SURE enough there was no squel and tapping...
Guess what the Rm 300 is just for a simple item which are these repair Kits...
Do you know the sequels are because of the worn out items listed here... so yeah I was so happy i gave him extra RM 50
:p
NOTICE ITEM: #10 #4 # 6
Its called the caliper Service kit...
Later did i learn that when uneven pressure applied on your rotor create those squeking and tappings...
Do try next time and just use an OEM pads... i also found out that this guy once work in reputable workshop before he decide to open his own...
Lesson of the day when all fails look at the mechanics of ur brake... or else BMW will not create Repair Kits for these item :)
Parts #
04 REPAIR KIT GUIDE BUSH 34111157038
10 REPAIR SET BRAKE CALIPER 34111153202
06 GUIDING BOLT 34111157041
BONUS... Bmw already know the issues and when all fail they use this :)
13 Brake pad paste 3G 83192158851
What this paste do is seep in the pads and create some sort of lubricated dusts
herbert, how's the new zimmermann performing compared to the ori BMW?
