etquah;467901 said:Cant avoid the scratches. You dont scratch yourself, someone else do it for you. I also have some many chips on the front bumper & a few paint chips on the bonnet. Anything can be done to avoid this ?
astroboy;467866 said:Sand polishing? Use fine sand paper la..yep, the entire panel will be sanded down to a very thin layer and yes, most of the clear coat is removed in the process. That's why I leave the scratches alone, if my ScratchX couldn't do the job. I just treat it as wear and tear, as long as doesn't rust. My car is not going for any competition ma..
Car detailing center know what to do when it comes to sanding. Do not straight away ask them to sand, they will advise u accordingly. Maybe rubbing compound will do the job, which is a lot less abrasive than sanding.
Look for a reputable one because they have proper technique or instrument to gauge the paint thickness and not simply sand their way down into the primer..![]()
Guna;468097 said:There you go,that's another alternative though I'm sure like what Astro said,our local fellas will make it sound like it's some kinda rocket science and charge you the price of a rocket launch to fix it
Trailing distance would obviously be a factor la but eventually no matter how careful you may get,it's gonna chip.In the past what I've done is wait till it gets pretty obvious and then send it for a respray of the front but you gotta find a paint shop which does a good job la.
What I have right now is just the headlight protective film.Bumper can respray ma.headlights make big hole in pocket.
astroboy;468038 said:Aiyaa... front chip is because lack drivers experience..![]()
Who ask u to go "tiong" others... especially Avanza.. and other MPV or even cement trucks.. Stay away la!![]()
So your windscreen have chips too? Normally if you have serious front chip and windscreen stone marks, that means its high time you need to adjust your trailing distance with other vehicles.
Can consider 3M clear mask and I think if order in bulk from US, its US$0.25 per foot run of 24" wide. The local fellas will slap u with a high price for the job, as high as respray the car.. :stupid:
This is the OEM part:
1. Clear covering, PN: 82 11 0 399 148, E90 HOOD/MIRROR
2. Clear covering, PN: 82 11 0 399 149, E-90 BUMPER
etquah;468103 said:Hi Guna, where to buy the protective film for headlight ? I agree with you, no matter how careful, sure kena. sometimes you are in the next lane about to overtake the lorry also can kena. Nowadays, fi see lorry lari kuat kuat![]()
etquah;468109 said:... If need stick so many things to keep our car perfect also doesnt sounds right. Might as well park in the house & admire. Sure PERFECT
astroboy;468150 said:There u go...Its just a car.. A little stone chips won't make the car depreciate any more than it is now..
.. and it doesn't even hurt the drive-ability of the car.. the best part is, these little chips make your car unique from others.. mine even have birth marks!!![]()
etquah;468165 said:..AB any suggestion which shop to go to fom Guna's reply ?
