RPM - Help Needed
cas
my ride is e36 intermittently if i stop the car at a traffic light the RPM will drop below 0.5 then back to slight below 1, sometimes when i push to D it will have the same prob, its very rare, only happen sometimes, is this normal, if not what could be the problem ?sifu's pls advise !
Normal is rock steady all the time.
Check the idle control valve, as well as the throttle position sensor, as indicated below.
bro.. how much does it cost to replace the sensor, and its intermittent is it any prob if it not replaced
The above illustration is for M42.
This one below is for M52, item labeled no. 6.
Cas,
Searched, and found you are driving a 318.
This item seldom fails. It is more likely dirty.
Go to your regular workshop, and have it cleaned.
To replace, it costs around RM600+
