Bimmerman, and Kahar....Originally posted by bimmerman@Apr 1 2005, 06:32 PM
My car came with it and I also have the switch mounted near the rear passenger aircon vents. The whole original setup but the blinds were nowhere to be found! Being a curious person by nature, I dismantled the rear seat and removed the board (parcel shelf) and lo and behold! Someone had hidden the whole electric blind unit under the board and plugged it out as well.
Why would the previous owner do that? I also found some broken glass bits near the area. I want to fix it back but can't figure out how it's mounted. :dunno:
Originally posted by 5201+Apr 1 2005, 07:39 AM-->QUOTE (5201 @ Apr 1 2005, 07:39 AM)
ThanksOriginally posted by teejay@Apr 3 2005, 11:32 AM
bimmerman, try this and see if you have all the parts for it,
http://www.realoem.com/bmw/partgrp.do?PHPS...700&hg=51&fg=60
armereth,
you need to replace switch, or get it overhauled, guru jarance can help with it, and me too
but im not in kl at the moment, and hardly
attend the TT, your switch could be stuck or corroded, it needs to be opened up and cleaned thoroughly, other then that, there is a loose connection somewhere or a bad earth body connection
