chairoger;568315 said:Thanks for the info bro. Managed to sneak away for a few hours to my workshop. They still cant pinpoint the problem but the diagnosis was the burglar alarm is interfering with the sensor/locking switch. Motor/actuator all functioning as per normal separately. They sent the diagnosis to Germany for further consultation. Sounds expensive sia.
I personally feel I just need to temporary switch off the rear bonnet sensor switch (part no. 61310119052) but have no idea where it is.
Do I need to strip the carpeting from the rear bonnet to access the rear bonnet sensor switch? Thank you in advance.
According BMW WDS info, :top:
the boot motor lock, lock switch, boot lock switch, rear boot open switch are all control by the GM5 module. The GM5 module control the central locking (door), boot, fuel filler and also the power windows.
The boot lock is located here.
The rear lock switch is located here.
and the rear boot open switch is located here.
