mnk
- Dec 14, 2004
- 575
alpina b5;460645 said:yuck....horrible, bmw bikes are the best
wat type of bmw bike did u own...??:listen:
mnk;460794 said:wat type of bmw bike did u own...??:listen:
nazrie;461039 said:Not yet in Malaysia lah boss.... I am in Paris at the moment and just a coincidence the bike made a stop here for 1 day only .. mau pesan apa apa ka? I am staying betul betul kat bike shops area.. esok mau pi borong barang Dainese untuk kengkawaaan.. Just for info, Dainese said there are no longer making Rossi replica suits , boots and gloves . They are only coming up with signature edition only. So, those whom have REPLICA items, hold on to those..value gonna go up and up and up...
nazrie;460894 said:
If on looks alone , I 'd get the Ducati 1198.. so, mana satu eh.. yang lawa atau yang sedap main ?
BMW S1000RR
Displacement: 999.00 ccm (60.96 cubic inches)
Engine Type: In-line four
Stroke: 4
Fuel System: Injection
Valves: 4 per cylinder, titanium, with individual cam followers
Fuel Control: DOHC
Engine output: 193 hp (142 kW) at 13,000 rpm
Peak Torque: 82.5 lb-ft (112 Nm) at 9,750 rpm
Dry Weight: 403.4 pounds (183.0 kg)
Wet Weight: 455..3 pounds (206.5 kg)
Power-to-weight ratio: 2.31/2.34 pounds per horsepower without/with Race ABS
Starter: Electric
Lubrication System: Dry sump
Cooling System: Liquid
Gearbox: 6-speed
Transmission type final drive: Chain
Clutch: Multiple-disc clutch in oil bath, mechanically operated
Overall length: 84.4 inches (2,145 mm)
Frame Type: Bridge-type aluminium fram, load-bearing engine
Rake (fork angle): 25.8º
Trail: 3.7 inches (95 mm)
Front suspension: Telescopic fork, Ø 43 mm
Front suspension travel: 125 mm (4.9 inches)
Rear suspension: Cast aluminium single-sided swing arm with eccentric adjustment for rear axle, central spring strut, spring pre-load hydraulically adjustable (continuously variable) at handwheel, rebound damping adjustable
Rear suspension travel: 4.9 inches (125 mm)
Front tire dimensions: 120/70-ZR17
Rear tire dimensions: 180/55-ZR17
Front brakes: Double disc. ABS
Rear brakes: Single disc. ABS
Exhaust system: Closed-loop 3-way catalytic converter, emission standard EU-3
Top speed: 124.3 mph (200.0 km/h)
Exhaust: Small and short rear-end muffler, pre-silencer and electronically controlled interference pipe flaps as well as a fully controlled exhaust gas manifold and two fully controlled three-way catalytic converters.
Fuel Tank: Aluminum for reduced weight
Color options: Mineral Silver metallic, Acid Green metallic, Thunder Grey metallic, Alpine White/Lupine Blue/Magma Red.
Comments: Optional Dynamic Traction Control in conjunction with Race ABS. Various riding modes available at the touch of a button for wet surfaces, regular road requirements, race tracks with sports tyres and race tracks with slicks. Optional HP Gearshift Assistant for shifting up without operating the clutch and without the slightest interruption of torque and pulling power.
Cylinder head and cam follower valve drive based on BMW Formula 1 technology.
Loaded in base trim the S1000RR is replete with Dynamic Traction Control (DTC) and race-ready ABS along with Formula 1-inspired valve actuation the S1000RR is a technophile’s dream. Following the example of BMW ’s Formula 1 engines, the two intake and exhaust valves per cylinder made of extra-light titanium are operated by very small and equally light single cam followers. In conjunction with the short sprocket driving the camshaft via an intermediate gear, this ensures supreme revving qualities at the highest speeds as well as exact maintenance of valve timing combined with very compact dimensions.
it says " Feels more powerful than an R1" &
"the best bike I've ever ridden and makes the suspension of the Fireblade feels rubbish in comparison"
and he owns a Fireblade as his track bike..
Chris Pfeiffer's Autograph Edition F800R
