Parktronic / PDC / Park Assist
jbswong;622048 said:
i order a PDC unit from germany and installed now but no working and i already done with SSS.
what wrong ?
SSS > final report ...? GT 1 > fault store.... ?
Hi Guys,
I own E39 2003 model was wondering any you guys have this problem after engaging back to D while moving forward my rear sensors will still go on for about 1 minute tee tee tee tee than the PDC switch green light goes off, why? The front is fine the sensors works when nearing object only.
I have checked all around the car all sensors have the tik tik tik sound.
herbert;708568 said:
That is normal.
bro before this it was not like that...........reasonly last time when u engage to R its gives a beep sound closing in towards object the beep will go faster and faster until beeeeeeeep for you to stop.
cyne;708613 said:
Actually, I was wondering, how would this actually work with the PDC concurrently ? Do we need to disable the PDC function first ?
It works with the PDC. When the PDC is on the camera is on. When the PDC is off, the camera is off. No need separate controls.
