Grand
- Jun 4, 2007
- 189
- 16
ICEMAN 13;527607 said:wow bro 1st time hearing that you need to press the accelerator a bit during stationery ...i believe you'll soon be facing problem by burning up your autobox as you're putting load on the car when it's stationary and the same time your brake pads are increasing in temp ....
just my 2 cento
What I mean is you press the accelerator a bit when the gear is in N and once you sense the fan operating, you can take your feet off the pedal. If this doesn't switch on the fan, then only I put the gear to D and press the accelerator with my left foot firmly on the brake.Once the fan is on, you may take your foot off the pedal. At least it works for me last time.May only be applicable on a case to case basis.
