tamade7;283709 said:You can go the expensive by change your LCM. Cost around RM700++ I think
Daniel;283728 said:Have you tried pulling out fuse no. 32?
joeylow;284081 said:Common problem, it seems that only China made HIDs give the error but philips ones don't. That is wat I heardlar. Anyway there is 2 ways to defeat the error.
1st : Install a condenser/capacitor in parallel to the car's original H7 wiring. Note the positive and negative connections as the capacitor is also polarised. You should use a value of 10,000uF(can purchase this from electronic part shops)
2nd : There is a relay + resistor circuit running around the web. You have to do some searching for it. It will also by pass the error.
actually there is one more. The guy that sold you the HID should have a KIT that also disables the error. If he did not offer you the KIT then he might not be an experienced installation especially on a BMW. But I think the KIT is also one of these solutions that I have mentioned above.
joeylow
soorian;283712 said:Bro. What is LCM ? Where to get this ?
Mine is Projector lights, and it OEM BWM. i bought it from MotorSports Division.
Thanks
Zee77;284882 said:Hi Soorian, can i know what is the display on the obd? I just installed angel eyes on my e46 (kena racun by u guys lar!!) and the next day i noticed that the engine oil pressure warning light comes on for a few seconds everytime I start my car. I have checked the engine oil dipstick but it is within normal range and i've just serviced my car last month.. Weird.. Now, i am thinking of installing HIDs but it sounds like it's gonna complicate the matter with so many things to change as recommended by tamade7..
